Hello Guest it is April 20, 2024, 11:30:44 AM
Author Topic: touch probe plugin  (Read 13203 times)
touch probe plugin
« on: April 01, 2014, 06:54:40 AM »
New mach3toolcam update
http://www.mach3toolcam.top-eb.fr
thanks
Re: touch probe plugin
« Reply #1 on: May 17, 2014, 04:01:59 PM »
I was wondering if anyone out there could help me.
My Mach3 machine runs well however when I set up the probe to pin 3 port 2 of my ESS C25 Smoothstepper board, when grounding the (wire shielded)to the machine frame the digitizer led flashes on and off in the diagnostics screen. I would assume that this tells me that I have continuity between my probe input and ground. Should this led not stay on as long as the probe is grounded?
I have also installed the Big-Tek Big Blue Probing screen. In the blue screen when I probe the Z axis, the z axis move but does not stop when contact is made with the probe, although the screen probe led flashes on and off.
I have also tried a G31 X 5.0 move in the MDI screen and the axis moves and stops when I ground the probe wire, but the motor continues to vibrates like it’s not completely shut down. Any suggestion?
« Reply #2 on: June 24, 2014, 05:00:10 AM »
Why did not I see Link is broken or not I've posted a new link here.
