Hello Guest it is April 24, 2024, 07:54:26 PM
Author Topic: How to make a popup when a button is selected?  (Read 8254 times)
Offline mike^3
  •  116 116
« on: March 22, 2014, 04:41:08 PM »
Hello,
Can anyone help me make an onscreen button pop up a message? Once you hit OK then the box will disappear?
I just need the VB script to say "Make sure Turret UP button is pressed before homing turret!"
Thank you!
Mike
Re: How to make a popup when a button is selected?
« Reply #1 on: March 22, 2014, 04:50:27 PM »
msgbox ("Make sure Turret UP button is pressed before homing turret!")
Offline mike^3
  •  116 116
« Reply #2 on: March 22, 2014, 04:53:07 PM »
Thanks, but I think I have a problem...the button I put was to home A. Can I put the Home A macro in the VB script after the msg box?
I would like to press the Home A button, have the msg pop up, click ok, then run the homing cycle for A.
Thanks ger!
« Reply #3 on: March 22, 2014, 05:00:21 PM »
Yes. I think it's #24
DoButton(24)
Offline mike^3
  •  116 116
« Reply #4 on: March 22, 2014, 05:15:15 PM »
DoButton(24) seems to home just the Z, what the number for A axis?
« Reply #5 on: March 22, 2014, 05:41:05 PM »
Try 25
Offline mike^3
  •  116 116
« Reply #6 on: March 22, 2014, 06:56:04 PM »
Can you have a command prompt with an ok or cancel in the dialog box? So I can cancel out of it instead of continuing the homing...?
« Reply #7 on: March 22, 2014, 07:38:16 PM »
I'm not sure. You'll need to look through the examples in the Cypress Basic manual.
« Reply #8 on: March 22, 2014, 07:51:52 PM »
Try this.
Response = MsgBox ("Warning !!!" & (Chr(13)) & ""Make sure Turret UP button is pressed before homing turret!" & (Chr(13)) & "Press OK To Continue" & (Chr(13)) & "Or Press Cancel to Exit ",49,"Press Turret Up Button!!")
   If Response = 1 Then ' If OK
      ' Continue Homing
      ElseIf Response = 2 Then ' If Cancel
      Exit Sub
   End If
Offline mike^3
  •  116 116
« Reply #9 on: March 22, 2014, 10:39:47 PM »
Thanks! Let me try that real quick :)
