Hello Guest it is November 30, 2026, 12:43:14 AM
Author Topic: 4th axis turns for 359° instead of -1°  (Read 39166 times)
« on: March 20, 2014, 03:02:32 AM »
Hello, I am trying to use the 4th axis with solidcam, and in fact in works, but when it does movement outside the material a good thing would be that it wouldn't do a full rotation when it goes (for example) from 355 to 0.
Here is a gcode example:
Code: [Select]
S1000 M03
G00 G54 G90 X21.5875 Y0. A-88.588
G43 H1 Z30.
G01 G94 Z13. F300.
A270. F600.
G00 Z35.
X19.5875 A-88.588
Z33.284
Thanks in advance !
Re: 4th axis turns for 359° instead of -1°
« Reply #1 on: March 20, 2014, 06:08:14 AM »
A few choices are allowed in configuration. See "Rotational" selections above Screen Control on the configuration page  and have a read of what they do in the manual .
« Reply #2 on: March 20, 2014, 06:12:47 AM »
 This works with G0 rapids, but not with G1's.
(on the Gen Config page)
Russ
« Reply #3 on: March 20, 2014, 06:14:37 AM »
ooops, that's one FAST bug you're riding there Rich.  :D
Russ
« Reply #4 on: March 20, 2014, 06:22:03 AM »
Hey Russ, no need for speed just better to enjoy the ride. >:D  :D
Have Cabin Fever yet?
« Reply #5 on: March 20, 2014, 06:26:46 AM »
Just somehing to consider on the rotation. If you have backlash it may be better to have it rotate in the same direction so  it is taken up.
« Reply #6 on: March 20, 2014, 06:29:07 AM »
 no need for speed   >:D  :D
Maybe that's not a bug ... .it's a TURTLE.
Heck yes, I'll be there !
You get us vendor passes yet ?
Oh yeah, good point on the backlash !  ;)
Russ
« Reply #7 on: March 20, 2014, 08:48:39 AM »
Sorry in advance for the following questions but maybe I'm too "newbie"...
I don't find the setting nor "screen control" and what is the configuration page (settings or config menu) ?
Same question for "Gen config page" do we speak about mach3 ?
EDIT: I seems that I have an old version of mach3, will try to update...
« Last Edit: March 20, 2014, 09:01:13 AM by greg2fs »
« Reply #8 on: March 20, 2014, 09:18:25 AM »
(menu bar) Top left of the screen, click on Config.
Then in the drop down, click on General Config.
Then near the lower right you see the Rotational settings.
Russ
« Reply #9 on: March 20, 2014, 09:26:47 AM »
If your version is VERY old, Mach2, it will be a bit different.
If this does not fix you, post your version .... or like you say, update to a newer one.
Russ
