Hello Guest it is April 27, 2024, 12:04:23 AM
Author Topic: Mach Blue Probing by Big-Tex - new version 3.4 avaliable soon  (Read 61764 times)
Re: Mach Blue Probing by Big-Tex - new version 3.4 avaliable soon
« Reply #10 on: March 31, 2014, 07:59:14 PM »
Officially out.
Thank you alll for great support
Thomas
Thank you for your support in developing better cnc experiance.
 Scan my avatar with smart pnone .......
http://big-tex.tk/
« Reply #11 on: April 05, 2014, 05:03:44 PM »
I'm having trouble loading the screen set.  It's as if the JPG is not loaded or found.
« Reply #12 on: April 05, 2014, 05:10:44 PM »
please let me know where is your mach 3 installed?
C://mach3
Thomas
http://big-tex.tk/
« Reply #13 on: April 05, 2014, 05:14:36 PM »
Keep in mind during install you need to indicate where mach3 is installed.
I do have youtube video showing installation process
https://www.youtube.com/watch?v=lVX537uj1cU&feature=youtu.be
Its is also good idea to have previous verion of my screen uninstalled as good measure.
Its been several years and I did not have all of my old filles to create installer as upgrade.
« Last Edit: April 05, 2014, 05:27:47 PM by big-tex »
Thomas
http://big-tex.tk/
« Reply #14 on: April 21, 2014, 11:07:22 AM »
I am having the same issue with my screenset.  All the files are in the correct location, loads but all I get is the black death.  I have tried this on two different machines and also tried different profiles to see if there was something in the profile that was messing it up.  Any suggestions for a fix?
Thank you,
JH
« Reply #15 on: April 21, 2014, 12:28:42 PM »
Shot me emails I will resend install files, just in case of corruption
Thomas
http://big-tex.tk/
Offline ZASto
  •  423 423
« Reply #16 on: April 21, 2014, 12:48:26 PM »
Hi Thomas,
can you send me your script for TC Zero Setup?
I'm using your latest public domain screenset, heavily modified for all the functions to be mm/inch, and found, just yesterday, that if the fixed plate is higher than material surface, tool is never reaching material for cutting.
10x
My personality is who I am.
« Reply #17 on: April 21, 2014, 01:10:26 PM »
It should be cutting fine calculated offset will be positive #, if plate is below material it will be negative #.
If you refer to verions prior to 3.4 you need to do it using my site to get files.
Thomas
http://big-tex.tk/
« Reply #18 on: April 22, 2014, 12:39:24 AM »
issue fixed check your email
if something needs further rework let me know
Thomas
http://big-tex.tk/
Offline ZASto
  •  423 423
« Reply #19 on: April 22, 2014, 03:05:49 AM »
Thomas,
thank you for your kind offer, M'a Baker style :)
Will have to put my brain to overdrive again.
« Last Edit: April 22, 2014, 03:08:26 AM by ZASto »
