Hello Guest it is April 17, 2024, 09:05:21 PM
Author Topic: 3D HumanFace  (Read 25394 times)
Re: 3D HumanFace
« Reply #10 on: March 29, 2014, 09:14:30 PM »
The blue field is the hi res path viewed from straight down look at it from an ISO perspective or side view you will see the face in there.
Steve
OMG! That's it! At least it some kind of face. I only just now realized what you were telling me. I'll run it in the morning and see what I get.
Re: 3D HumanFace
« Reply #11 on: March 30, 2014, 06:29:51 PM »
I have an stl of a whole bust if interested. Would be interesting to see it done.
I have this ultimate set of tools I can fix it.
Re: 3D HumanFace
« Reply #12 on: September 02, 2014, 02:06:54 PM »
Hi newbie here ,What type and size tool will work best. ???
Please be gentle  ::)
Regards Dave
Re: 3D HumanFace
« Reply #13 on: September 02, 2014, 06:48:27 PM »
Regards Dave
Type of tool would depend on the material you are cutting. Size would be the smaller the more detail. I would need to look up the file and see what size was used to generate the code.
I see the file was downloaded 522 times be nice of some of them shared their results and experiences.
« Last Edit: September 02, 2014, 06:50:30 PM by Machinehead57 »
Re: 3D HumanFace
« Reply #14 on: September 03, 2014, 04:58:23 AM »
Thanks for the reply , I was thinking softwood to start  :-\
Regards Dave
Re: 3D HumanFace
« Reply #15 on: September 03, 2014, 10:14:33 AM »
I wouldn't use soft wood it has large fiber and doesn't shear cleanly. Use a piece of poplar it has small grain and is hard enough to cut cleanly.
Use a 1/4" ball nose. Is this a router or a mill?
Steve
Re: 3D HumanFace
« Reply #16 on: September 03, 2014, 10:56:53 AM »
Thanks for that its a home build cnc  router.
Regards Dave ;D
Re: 3D HumanFace
« Reply #17 on: June 25, 2017, 11:00:08 AM »
where can this file be found
thanks
Re: 3D HumanFace
« Reply #18 on: June 25, 2017, 11:56:29 AM »
The file can be downloaded from the first page of this thread. There is a blue face file another member posted also.
good luck
Steve
Re: 3D HumanFace
« Reply #19 on: June 25, 2017, 03:38:46 PM »
http://www.machsupport.com/forum/index.php/topic,28821.0.html
Here's another thread with some code about a human face.
