Hello Guest it is April 26, 2024, 06:29:23 AM
Author Topic: G-CODE Button Problem  (Read 2950 times)
« on: March 12, 2014, 03:08:54 PM »
I placed a Button on screen. Then I entered the text for it, "G-CODES". Next I clicked on the FUNCTION box in the MachScreen Properties Dialog box and selected "Execute Basic-Script" (this was the only Function listed in either OEM or Standard) that appeared even close to what I wanted to do). When I selected this Function, the Standard Code  box changed to 34. Also, LOADFILE (C:\Mach3\MillBitmaps\G-code_US.bmp) appeared in the Execute code box.
I want this button to open the file on screen that shows the list of G-Code numbers and their functions. (I plan on a similar button for M-Codes). When I save the Screen and load it into Mach3, when pushed, the button does nothing! The file called is spelled correctly and in the path listed in the Execute Code box. I have no idea why this will not work! Anybody got an idea???
Bob
"For those who fought for it, Freedom has a flavor the protected will never know"
UNKNOWN
G-Code Button problem
« Reply #1 on: March 12, 2014, 03:35:42 PM »
Disrecard my above post!
« Last Edit: March 12, 2014, 03:49:04 PM by BOHICAMAN »
UNKNOWN
