Hello
Guest
it is
April 25, 2024, 01:14:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mdi question
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mdi question (Read 2927 times)
moto52000
15
Mdi question
on:
March 07, 2014, 02:03:05 PM »
Hi all, quick question. When I input say, X2 F10 I was expecting to move 2 in X at a feed of 10. I get the email expected 2 in X but feed rate does not change. What am I doing wrong?
Sent from my Galaxy Nexus using Tapatalk
Logged
Overloaded
4,922
Re: Mdi question
Reply #1 on:
March 07, 2014, 02:29:04 PM »
You may be still in the modal G0.
Enter G1 X2 F10 and see what you get.
G1 is modal also.
Just a guess,
Russ
Logged
moto52000
15
Re: Mdi question
Reply #2 on:
March 07, 2014, 02:39:26 PM »
Thanks. I bet that is it because I swear it worked for me in the past. Is there a proper entry method to be sure it always works? If both are modal, do I just toggle it each time?
Last Edit: March 07, 2014, 02:58:30 PM by Overloaded
Logged
Overloaded
4,922
Re: Mdi question
Reply #3 on:
March 07, 2014, 02:56:58 PM »
Unless I'm absolutely sure which is active, I will include it every time when MDIing.
Due to my inexperience
, my cnc is full of surprises
... so I try to keep them to a minimum.
A rapid, when unexpected can raise the heart rate considerably.
Russ
Logged
Fastest1
920
Houston, TX
Re: Mdi question
Reply #4 on:
March 07, 2014, 11:36:54 PM »
I do it as Russ does too, if hand coding line by line it is always a G0 or G1.
Logged
Print
Pages:
1
Go Up
« previous
next »
