Hello Guest it is April 26, 2024, 11:23:38 AM
Author Topic: I Need A help  (Read 6291 times)
Offline sa
  •  1 1
I Need A help
« on: March 06, 2014, 03:41:07 AM »
i need some one to help me to write a G-code according to this note.
 The drawing represents a 2.9" long piece of hardwood, 1" in diameter (not necessarily drawn at full scale.)  Assume the use of a right-cut tool (T1) with a maximum depth of cut of 0.1", a spindle speed of 1500 RPM, and a feed rate of 3 inches per minute.  Assume ½" of the 2.9" length to be in the chuck, with the chuck face at Z=0.  (The Y-axis is labeled assuming ½" is in the chuck.) Start the tool even with the edge of the stock, and 0.1" to the right. Include a cut-off routine (T3, feed rate of 1 IPM) so the final piece is 1.9” long and return to the starting point at the end of the program.
Challenge: Write efficient NC code to machine the part on our lathe.  First, use absolute coordinates. Then write the control code again using relative coordinates. Two separate programs are due.
thanks
  •  9,200 9,200
Re: I Need A help
« Reply #1 on: March 06, 2014, 06:45:48 AM »
Hi Sa,
Very few people actually write their own GCode nowadays although someone may rise to the challenge.
Perhaps best if you draw your part in CAD/CAM (plenty of free versions available) then use it’s post-processor to create the GCode.  ;)
Re: I Need A help
« Reply #2 on: March 06, 2014, 07:28:48 AM »
sa,
Why should we do your homework?
Re: I Need A help
« Reply #3 on: March 06, 2014, 07:47:08 AM »
Instructor mislabeled the cross axis, and made no reference to Tool nose radius.
and this is what students are learning to be educated in CNC?
Offline Eli
  •  13 13
Re: I Need A help
« Reply #4 on: March 22, 2014, 02:48:44 PM »
I'm at a point where I need one on one help. Anyone near Monroe NY who is willing to give up some hands on time for a reasonable fee, please email Eli at 1american@optonline.net and I will explain what I have and what I'm looking for. I built a plasma/router machine over 2 years ago and I have yet to cut anything. Thank you.
