So I did a test.
Put a slotted disc directly on the .5 hp motor, nothing else, no load. Mounted the sensor.
Mach reports 1797-1799. No Index debounce set, Not averaging.
Put 2 precision machined V pulleys on, new v belt plenty tight, remounted the sensor at the spindle disc.
Mach reports 195* - 199*. WAYYYY to goofy to cut good threads.
(pulley ratio is just what I had available for the test, I'd normally reduce about 2:1)
The belt is not perfect, but it's new and shouldn't wander the spindle rpm THAT much, but maybe a little.
Is the motor too small maybe ? It doesn't slow during threading, it's just not stable.
Does it need a timing type belt and pulleys maybe ?
I know, I know .... a servo would be the bees knees, I know. Or a vector type motor and drive with feedback, both a bit pricey.
I'm seeing more and more why commercial units cost so much.
Russ
