Hello Guest it is April 16, 2024, 10:48:46 AM
Author Topic: Art 1 error and Mill screens not loading  (Read 3592 times)
« on: February 17, 2014, 02:09:56 PM »
I have been using Mach 3 turn for about a year now with no problems. However, recently I started to get this message: crror code: Art 1, Attempt Receovery?. When I click "Yes", it turns on the usual manual, and auto turn screens and I can run Trun with no  problems. Having become comfortable with Turn, I now want to use Mach3 Mill but when I click on the loader it generated the same error, but when I click "Yes" for "attempt recovery" I get various Artsoft logos each time I click. It thengoes to a matt colored screen Artsoft, with a brief flashor various DROs before I get a blank screen with the usual headers on top (file, config, view, etc.,) When I select a mill wizard  I get the screen (similar to turn) where you put the inputs. Not sure what is happening here? I know when I first installed mach3 and tested the Mill loader, it opened a Mill screen without any problem.
Joe
Re: Art 1 error and Mill screens not loading
« Reply #1 on: February 17, 2014, 02:33:44 PM »
First, it sounds like you need to reinstall Mach3 to get rid of that error.
Then, it sounds like your Mill screen bitmaps are missing from Mach3\bitmap\Millbitmaps (or something like that)
« Reply #2 on: February 17, 2014, 07:17:07 PM »
Thanks for the reply. i will reload Mach3. I did find the bitmaps but they seem to be the components you would use to create/customize a screen. Ihappened to find in the mach3 folder a folder called 1024 which had .lset files and, of course for the mill. .set files. When I clicked that I did get a screen with the Auto. MDI, etc. tabs which I am now using. Since the error code worries me, I will reinstall.
Thanks again
Joe
