Hello Guest it is April 26, 2024, 09:24:35 AM
Author Topic: Pokeys xml location  (Read 4988 times)
Pokeys xml location
« on: February 12, 2014, 06:10:05 AM »
I need to know where the pokeys config file is located so I can transfer all of the settings to a fresh Mach install.
I had a motherboard go bad so I built a new computer. I kept the old hard drive & set it as a slave. Installed a fresh copy of Mach on the new drive & transfered my xml file over. All of my Mach sttings are there, but when I open the pokeys plugin all of my settings are gone.
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys xml location
« Reply #1 on: February 12, 2014, 10:55:05 AM »
The PoKeys plugin settings are located in
C:\Users\{your name}\AppData\Local\PoKeysMachConfig.xml (Windows 7/8)
C:\Documents and Settings\{your name}\Local settings\Application Data\PoKeysMachConfig.xml (Windows XP)
« Reply #2 on: February 12, 2014, 12:20:10 PM »
Thanks!
I'll try moving it over tonight.
