Hello Guest it is April 20, 2024, 12:05:24 AM
Author Topic: GCODE causes problem.  (Read 3489 times)
« on: February 09, 2014, 10:18:43 PM »
Can anyone tell me why this gcode is causing the circles around the toolpath origin? I have attached a photo of the mach3 screen, a photo highlighting one of the offending lines, another photo with another offending line. It seems to be every other g2 line. Attached id the xml file for this machine, I am on windows 7 Plenty of cpu power. If I take out the holes with the g2 code it runs fine. I don't know what the problem could be. The problem starts at the drill 13 section. I am using a 3/16 (4.8) bit to make a 1/4" (6.3) hole.
Code: [Select]
( Made using CamBam - http://www.cambam.co.uk )
( panel_all-in-one 2/9/2014 8:27:27 PM )
( T0 : 4.8 )
( T1 : 4.8 )
G21 G90 G64 G40
G0 Z3.0
( T1 : 4.8 )
T1 M6
( Drill1 )
G17
M3 S1000
G0 X7.5 Y92.5
G98
G81 X7.5 Y92.5 Z-2.9 R3.0 F300.0
G80
( Drill2 )
S1000
G0 Z3.0
G0 X81.0 Y93.0
G98
G81 X81.0 Y93.0 Z-2.9 R3.0 F300.0
G80
( Drill3 )
S1000
G0 Z3.0
G0 X141.0
G98
G81 X141.0 Y93.0 Z-2.9 R3.0 F300.0
G80
( Drill4 )
S1000
G0 Z3.0
G0 X152.5 Y92.5
G98
G81 X152.5 Y92.5 Z-2.9 R3.0 F300.0
G80
( Drill5 )
S1000
G0 Z3.0
G0 X111.0 Y84.0
G98
G81 X111.0 Y84.0 Z-2.9 R3.0 F300.0
G80
( Drill6 )
S1000
G0 Z3.0
G0 X91.0 Y41.0
G98
G81 X91.0 Y41.0 Z-2.9 R3.0 F300.0
G80
( Drill7 )
S1000
G0 Z3.0
G0 X113.0
G98
G81 X113.0 Y41.0 Z-2.9 R3.0 F300.0
G80
( Drill8 )
S1000
G0 Z3.0
G0 X131.0
G98
G81 X131.0 Y41.0 Z-2.9 R3.0 F300.0
G80
( Drill9 )
S1000
G0 Z3.0
G0 X7.5 Y7.5
G98
G81 X7.5 Y7.5 Z-2.9 R3.0 F300.0
G80
( Drill10 )
S1000
G0 Z3.0
G0 X81.0 Y6.0
G98
G81 X81.0 Y6.0 Z-2.9 R3.0 F300.0
G80
( Drill11 )
S1000
G0 Z3.0
G0 X141.0
G98
G81 X141.0 Y6.0 Z-2.9 R3.0 F300.0
G80
( Drill12 )
S1000
G0 Z3.0
G0 X152.5 Y7.5
G98
G81 X152.5 Y7.5 Z-2.9 R3.0 F300.0
G80
( Drill13 )
S1000
G0 Z3.0
G0 X96.0 Y60.0
G0 Z3.0
G0 X96.8 Y60.0
G0 Z1.0
G1 F300.0 Z0.0
G2 F800.0 X95.6 Y59.3072 Z-0.3333 I-0.8 J0.0
G2 Y60.6928 Z-0.6667 I0.4 J0.6928
G2 X96.8 Y60.0 Z-1.0 I0.4 J-0.6928
G2 X95.6 Y59.3072 Z-1.3333 I-0.8 J0.0
G2 Y60.6928 Z-1.6667 I0.4 J0.6928
G2 X96.8 Y60.0 Z-2.0 I0.4 J-0.6928
G2 X95.6 Y59.3072 Z-2.3333 I-0.8 J0.0
G2 Y60.6928 Z-2.6667 I0.4 J0.6928
G2 X96.6472 Y60.4702 Z-2.9 I0.4 J-0.6928
G2 X96.0836 Y59.2044 I-0.6472 J-0.4702
G2 X95.2692 Y60.3254 I-0.0836 J0.7956
G2 X96.6472 Y60.4702 I0.7308 J-0.3254
( Drill14 )
S1000
G0 Z3.0
G0 X126.0 Y60.0
G0 Z3.0
G0 X126.8 Y60.0
G0 Z1.0
G1 F300.0 Z0.0
G2 F800.0 X125.6 Y59.3072 Z-0.3333 I-0.8 J0.0
G2 X126.8 Y60.0 Z-1.0 I0.4 J-0.6928
G2 X125.6 Y59.3072 Z-1.3333 I-0.8 J0.0
G2 X126.8 Y60.0 Z-2.0 I0.4 J-0.6928
G2 X125.6 Y59.3072 Z-2.3333 I-0.8 J0.0
G2 X126.6472 Y60.4702 Z-2.9 I0.4 J-0.6928
G2 X126.0836 Y59.2044 I-0.6472 J-0.4702
G2 X125.2692 Y60.3254 I-0.0836 J0.7956
G2 X126.6472 Y60.4702 I0.7308 J-0.3254
( Drill15 )
S1000
G0 Z3.0
G0 X91.0 Y29.0
G0 Z3.0
G0 X91.8 Y29.0
G0 Z1.0
G1 F300.0 Z0.0
G2 F800.0 X90.6 Y28.3072 Z-0.3333 I-0.8 J0.0
G2 Y29.6928 Z-0.6667 I0.4 J0.6928
G2 X91.8 Y29.0 Z-1.0 I0.4 J-0.6928
G2 X90.6 Y28.3072 Z-1.3333 I-0.8 J0.0
G2 Y29.6928 Z-1.6667 I0.4 J0.6928
G2 X91.8 Y29.0 Z-2.0 I0.4 J-0.6928
G2 X90.6 Y28.3072 Z-2.3333 I-0.8 J0.0
G2 Y29.6928 Z-2.6667 I0.4 J0.6928
G2 X91.6472 Y29.4702 Z-2.9 I0.4 J-0.6928
G2 X91.0836 Y28.2044 I-0.6472 J-0.4702
G2 X90.2692 Y29.3254 I-0.0836 J0.7956
G2 X91.6472 Y29.4702 I0.7308 J-0.3254
( Drill16 )
S1000
G0 Z3.0
G0 X113.0 Y29.0
G0 Z3.0
G0 X113.8 Y29.0
G0 Z1.0
G1 F300.0 Z0.0
G2 F800.0 X112.6 Y28.3072 Z-0.3333 I-0.8 J0.0
G2 X113.8 Y29.0 Z-1.0 I0.4 J-0.6928
G2 X112.6 Y28.3072 Z-1.3333 I-0.8 J0.0
G2 X113.8 Y29.0 Z-2.0 I0.4 J-0.6928
G2 X112.6 Y28.3072 Z-2.3333 I-0.8 J0.0
G2 X113.6472 Y29.4702 Z-2.9 I0.4 J-0.6928
G2 X113.0836 Y28.2044 I-0.6472 J-0.4702
G2 X112.2692 Y29.3254 I-0.0836 J0.7956
G2 X113.6472 Y29.4702 I0.7308 J-0.3254
( Drill17 )
S1000
G0 Z3.0
G0 X131.0 Y29.0
G0 Z3.0
G0 X131.8 Y29.0
G0 Z1.0
G1 F300.0 Z0.0
G2 F800.0 X130.6 Y28.3072 Z-0.3333 I-0.8 J0.0
G2 X131.8 Y29.0 Z-1.0 I0.4 J-0.6928
G2 X130.6 Y28.3072 Z-1.3333 I-0.8 J0.0
G2 X131.8 Y29.0 Z-2.0 I0.4 J-0.6928
G2 X130.6 Y28.3072 Z-2.3333 I-0.8 J0.0
G2 X131.6472 Y29.4702 Z-2.9 I0.4 J-0.6928
G2 X131.0836 Y28.2044 I-0.6472 J-0.4702
G2 X130.2692 Y29.3254 I-0.0836 J0.7956
G2 X131.6472 Y29.4702 I0.7308 J-0.3254
( Profile1 )
S1000
G0 Z3.0
G0 X0.0 Y-2.4
G0 Z1.0
G1 F300.0 Z-1.0
G1 F800.0 X159.5
G3 X161.9 Y0.0 I0.0 J2.4
G1 Y99.5
G3 X159.5 Y101.9 I-2.4 J0.0
G1 X0.0
G3 X-2.4 Y99.5 I0.0 J-2.4
G1 Y0.0
G3 X0.0 Y-2.4 I2.4 J0.0
G1 F300.0 Z-2.0
G1 F800.0 X159.5
G1 Y99.5
G1 X0.0
G1 Y0.0
G1 F300.0 Z-2.9
G1 F800.0 X159.5
G1 Y99.5
G1 X0.0
G1 Y0.0
G0 Z3.0
M5
M30
  •  9,198 9,198
Re: GCODE causes problem.
« Reply #1 on: February 10, 2014, 03:02:06 AM »
In Config / General Config  change your IJ Mode to Inc that will get rid of the crop circles.  ;)
In this instance, In your GCode define that the arcs have been created in Incremental Mode (as opposed to Absolute Mode) with G91.1 at the start of the code.
« Reply #2 on: February 10, 2014, 02:57:09 PM »
I was thinking crop circles but I didn't want to say it. Don't want people to think I'm whacky.
Thank you very much that took care of my problem.
  •  9,198 9,198
« Reply #3 on: February 11, 2014, 02:55:41 AM »
No worries Frank, everybody knows that I am whacky.  ;D
Pleased that you got it sorted.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #4 on: February 25, 2014, 07:47:07 AM »
Just wacky enough to keep all of our machines running correctly.
  •  9,198 9,198
« Reply #5 on: February 26, 2014, 07:33:31 AM »
