Hello Guest it is April 25, 2024, 08:40:03 PM
Author Topic: OEM Mach Remote Control  (Read 8778 times)
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« on: March 06, 2007, 08:42:12 PM »
Please wait for the video to load to see a demonstration of the screen, there is also a live screen available for testing below as well.
<a href="http://vileguitars.com/MachFlash/ScreenVideo/flvplayer.swf" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://vileguitars.com/MachFlash/ScreenVideo/flvplayer.swf</a>
<a href="http://vileguitar.com/Artsoft/TestScreens/Remoting/OEM March3 Remote.swf" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://vileguitar.com/Artsoft/TestScreens/Remoting/OEM March3 Remote.swf</a>
<a href="http://vileguitar.com/Artsoft/TestScreens/Remoting/Shuttle.swf" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://vileguitar.com/Artsoft/TestScreens/Remoting/Shuttle.swf</a>
<a href="http://vileguitar.com/Artsoft/TestScreens/Remoting/MDI.swf" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://vileguitar.com/Artsoft/TestScreens/Remoting/MDI.swf</a>
To open SWF file out side of IE download: http://download.macromedia.com/pub/flashplayer/updaters/8/flash_player_update3_flash8_win.zip
and install the Flash Playe Plug'in.msi
(The swf files are located towrds the bottom)Download the EXE files here:
http://vileguitar.com/Artsoft/ScreenVideos/downloads/RemoteEXE.zip
Input and idea's will always help, so give input input input!  ;)
-Please give OEM/VB or Action script code where needed.
-Please provide computer type/CPU usage and installed programs as well.
-Please provide machine tested on
Will work on a machine but please be cautious
Much more to come...
« Last Edit: September 23, 2007, 12:16:07 PM by zealous »
ynneb
Re: OEM Mach Remote Control
« Reply #1 on: March 07, 2007, 12:33:23 AM »
Is there any stopping you pal ? :)
Its pretty much say good bye to the mouse and keyboard now, and hello to full touchscreen control.
EDIT I have another good Idea to incorporate into the Jog module. I reckon you could do this using flash quite easy. This is an old thread, Virtual MPG http://www.machsupport.com/forum/index.php?topic=183.msg967#msg967
« Last Edit: March 07, 2007, 01:46:09 AM by ynneb »
Offline John S
  •  111 111
  • Nottingham England
« Reply #2 on: March 07, 2007, 08:21:26 AM »
Having trouble with these flash screens.
Loaded the latest flash driver as listed in the other thread.
Mach 3 loads with normal screens OK but when I load a flash screen the focus isn't on Mach3, title bar is greyed out.
When I click in the title bar to get focus it crawls and I mean crawls.
happens on office computer and stand alone machine computer with no internet, network quicktime etc.
If I reload Mach whilst it still has a flash screen enabled it starts off in focus then drop the focus almost immediately, hold the splash screen for far longer than with a set screen then you have to click to get focus.
I see I'm not the only one an unless the install is bullet proof then support is going to be a nightmare.
As regards input I'll do a post later but for now can we have the G Code text changed ?
Mid green on a light green background ?
Looks like the Italian flag, white cross on a white background......................
John S.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: March 07, 2007, 12:02:02 PM »
I'll work on putting an installer together to insure that every thing needed is installed,up to date and in it's right place.
You can change the GCode text normally in "Function CFG's"/Fonts, possible later this will be available in a Flash screen, you can also change the toolpath colors in "Config"/Toolpath.
I believe where at a point with the Flash screens to start pulling everything together and making it rock solid now.
John S, What type of OS,Computer,ext.. your running and as much of what you think could be happening.
I have found that CPU and RAM usage drastically drop's when using swf files.
