Hello Guest it is April 25, 2024, 03:49:30 AM
Author Topic: crash at Exit  (Read 5296 times)
crash at Exit
« on: January 09, 2014, 01:13:05 AM »
hi i've ver3.043.066 running a laser, it does perfect but at exiting the mach crashs, no matter no problem just maintenance hours will be lost (essential for my job) , i save these at end of each session manual.
are there others with the same problem?
  •  9,199 9,199
Re: crash at Exit
« Reply #1 on: January 09, 2014, 07:48:35 AM »
No problems here but I have reverted to using version 3.043.056.
Could you explain a bit more about "it does perfect but at exiting the mach crashes" how do you exit ?
Re: crash at Exit
« Reply #2 on: January 09, 2014, 08:57:04 AM »
sorry about wrong place
i means i've no problem during running a job and when it finishes and i close mach, a window reports an error occurred (in fact mach3 doesn't exit properly)and i lose maintenance hours data. :-[
this happens for sessions which takes more than hour and so
  •  9,199 9,199
Re: crash at Exit
« Reply #3 on: January 10, 2014, 07:47:28 AM »
Apologies, my poor choice of words. By 'no problems here' I meant that I have no problems with my setup of using Mach3 to control my laser.  ;)
Perhaps try using an earlier version of Mach3 (some have reported having problems with ver. 066, although not with lasers). Earlier versions can be downloaded from ftp downloads tab http://www.machsupport.com/software/downloads-updates/
As said I now use ver. 056 and this is just fine for me.
Hope this helps.
