Hello Guest it is April 25, 2024, 10:16:18 PM
Author Topic: Mach3 3D Printer  (Read 43018 times)
Re: mach3 3D printer
« Reply #20 on: September 13, 2015, 05:07:48 PM »
Thanks for the setting info. My machine can reach the top speed you have used without a problem.  My ways are THK ball ways that are very smooth in operation. My machine is an unusual configuration, X bolted onto a 200 lb cast iron table. Z column riding on the X way saddle, Y traveling on the Z column saddle. It's like a boring mill.  So for small objects it can have a very rigid work envelope. A big work envelope gets shaky at the Z and Y extremes.
« Reply #21 on: September 13, 2015, 05:29:42 PM »
mine is one of those Chinese 30x40 routers.  I call it the noodle router because of all the flex, but you know, new motors, and electronics, its a fun little toy.  I have some supported rails and bearings to stiffen up the Y, just gotta take the time to modify the machine and install them.
« Reply #22 on: September 14, 2015, 08:59:36 AM »
printed all night.
I love the texture and frosted look.
« Reply #23 on: September 14, 2015, 09:16:30 AM »
WOW, I like it too Robert !
That would make a real cool shift knob for a Beetle.
Nice work !
Thanks for posting,
Russ
« Reply #24 on: September 14, 2015, 09:22:16 AM »
that is the idea, but it needs a base and hole for the shifter.
My dad restored a VW camper bus that is red and white.  He is in the middle of doing a bug that will be blue.  So looks like I get to add onto the design.  Which I did not do, its a thingiverse model.  Was just fun to print.
Re: Mach3 3D Printer
« Reply #25 on: May 26, 2016, 09:52:40 AM »
Can you please tell us more about the electronics you use for the extruder temperature control. Did you use something like this one?
« Reply #26 on: August 10, 2017, 01:25:33 AM »
Amazing setup you have there, that yoda came out looking great.
