Hello Guest it is April 25, 2024, 06:54:33 AM
Author Topic: new to aspire and mach3 gcode help  (Read 9604 times)
« on: January 02, 2014, 11:35:10 AM »
I have recently built a diy cnc and have successfully run gcode from others on the internet.  I have also written some myself and used some of mach's wizards to create some.  All with very good success.
Machine and mach appear to be set up correctly.  I recently purchased aspire and am attempting to create gcode from vector images.  I can create the tool paths and everything looks good in the preview model. I export the gcode and load and run it on my cnc and it stops before the project is finished.  I have done this with 2 different projects and i can't figure out why it's stopping.
if someone wouldn't mind looking over my attached code for errors i would appreciate it.
Travis
Re: new to aspire and mach3 gcode help
« Reply #1 on: January 02, 2014, 11:54:17 AM »
You need a licensed version of Mach3 to cut more than 500 lines of g-code.
« Reply #2 on: January 02, 2014, 12:17:18 PM »
my copy of mach should be licensed
i will double check to make sure there is not some type of registration error
« Reply #3 on: January 02, 2014, 12:53:42 PM »
Your name should be in the title bar, or in Help > About Mach3.
« Reply #4 on: January 07, 2014, 12:40:36 AM »
Ok. Thanks.  This fixed it.  I thought I had registered the copy but I had not.   Sorry to have you answer this question for probably the thousandth time.
Sent from my iPhone using Tapatalk
