Hello Guest it is April 16, 2024, 02:15:15 PM
Author Topic: 4 axis hot wire foam cutter screen  (Read 6601 times)
« on: December 19, 2013, 02:33:28 AM »
Hi!
I would like to present you my work.
When I started to use my CNC foam cutter I can't find a screen for Mach, wich will be comfortable for use. Thus I did my own Screen.
This is a preview.
More information you can find here: http://www.foamwings.ru/f-scr_eng.php
If you have any questions please contact me here or by e-mail a-andrey-k@mail.ru
Thanks!
Offline Arbo
  •  50 50
Re: 4 axis hot wire foam cutter screen
« Reply #1 on: May 23, 2016, 10:04:41 AM »
Nice screen.  Curious, how do you generate the gcode to use with it?
Am fiddling with a 4 axis cutter now, have an old MM2001 and was going to use GMFC, but wondering if I should just go with mach and a 'normal' controller.
