Hello Guest it is April 16, 2024, 12:50:22 PM
Author Topic: Not going till the end of line  (Read 3931 times)
Offline viz
  •  17 17
« on: December 11, 2013, 05:27:07 AM »
Hello,
As always some problems and don't understand why so simple things can't be done easy way.
The spindle gets into to the material and goes straight till the end of the line, but before the end of line the spindle goes up. The feed rate is 2600mm/min, also tried with slower ~1300mm/min, but the result is the same. So after first cut i have to rotate the material 180 degree and cut again to get the same results in both ends.
I have attached my .dxf and .nc files (nc was written with Aspire)
  •  9,197 9,197
Re: Not going till the end of line
« Reply #1 on: December 11, 2013, 07:11:47 AM »
Viz,
Try running the code in Exact Stop motion mode (config / general config).
