Hello Guest it is April 26, 2024, 04:35:58 PM
Author Topic: x3 Mill Homing Switch Install Question  (Read 25247 times)
« on: December 04, 2013, 12:39:45 AM »
I have optical sensor homing switches on my X3 machine. My question is if I wanted to replace them with plunger limit switches, can I use the same wires that power the optical switch to power the plunger switch? Do I just transfer the wires to the connectors on the plunger switch to make it work? The reason I want to change switches is to obtain more X Y and Z travel without having to take the table apart to reposition the optical sensors.
Re: x3 Mill Homing Switch Install Question
« Reply #1 on: May 30, 2014, 08:00:46 AM »
Did you get an answer?
If not I can help.
How much more travel do you need? what is total travel?
