I am running a simple program to cut a step. since I am ganging parts in together in the vise I want to take the cut very lightly. I also have an overall condition where I always have to make adjustments before or after a program to get things within .001". So I can't just put in cutter comp and go all the way araound teh part and call it don. I have to do the right check and then adjust and redo. Then I do the left adjust and redo. If I was to go around the right would be too big and the left too small of a step. I know what is wrong right now, just don't have the moolah yet to get better components. So In this case I will adjust after the cycle and give a light finish pass to bring everything within .001.
here is the problem. In this program instead of making a X move and then increasing my radial DOC with Y and then going back to the start X position and then adjusting Radial DOC with Y again. I am going in a Z like motion. Moves are a combination of X and Y. I am trying to use G41 so the cutter is compensated. My problem is that during the first move which is a straight line (N60)without any Y movement, towarsd the end of that path, cutter comp sends the cutter to the other side of the path ( I wiped out 7 blanks like that). Then N70-N100 does all kinds of weird compensating.
(Tool 3/8” 3Fl Carbide)
N10 G20 G17 G90 G54 S6000 F32
N20 G0 Z0 X0 Y0
N30 Z-.325 M3 M8
N40 X-.072 Y.1505
N50 G1 G41 X.305 Y-.2245 P.1875
N60 X5.195
N70 X.0835 Y-.2615
N80 X5.195 Y-.2985
N90 X.0336 Y-.335
N100 X5.5 F28
N110 G40
N120 G0 Z0
N130 X0 Y0 M5 M9 M30
N100 X5.5 F28
N110 G40
N120 G0 Z0
I Just want this thing to compensate for the cutter that is between the edge of the workpiece and the column. I want this to work whether I am going in positive X direction or negative X direction. I tried
N20 G0 Z0 X0 Y0
N30 Z-.325 M3 M8
N40 X-.072 Y.1505
N60 G42X5.195
N70 G41X.0835 Y-.2615
N80 G42X5.195 Y-.2985
N90 G41X.0336 Y-.335
N100 G42X5.5 F28
N110 G40
N120 G0 Z0
But what happened was that there was in effect no cutter comp as when running under single block I can see that my Y position DRO was the same as the G code block commanded Y position
Anybody see what is wrong with my programming. I have been away from the machine for a month and I am back to asking simple questions.
