Hello Guest it is April 26, 2024, 02:22:20 PM
Author Topic: Connecting an unknown stepper  (Read 3971 times)
« on: November 21, 2013, 04:47:38 PM »
Recently I'm got the idea to turn a small Proxxon translation table into a CNC machine. I've brought two new motors for the X/Y, and those work fine with Mach3. I also got an old stepper from a very old Hard Disk (Rodime 5.25" ca 10MB, ca 1982). See attached pictures.
I'm sure it's a two phase 6 wire motor, but I do not know how to determine the correct order of the wires.
The first phase is: Red / White / Black (with White the halfway common)
The second phase is: Yellow / Green / Blue (with Green the halfway common).
Resistance per phase is 36 Ohm (thus 18 Ohm between Red/White or White/Black).
I'm using a bipolar 4 wire stepper driver, can someone help to deduct which colors are A, A_, B and B_? The motor doesn't follow the standard color codings.
Any other info on the motor (voltage, torque etc.) is welcome!
  •  9,200 9,200
Re: Connecting an unknown stepper
« Reply #1 on: November 22, 2013, 02:39:38 AM »
Hi Hobbit13,
Welcome to the forum.
The centre taps are not used so Red / Black (A, A) and Yellow / Blue (B , B) are your connections.
There is excellent info on steppers at the Gecko site here  http://www.geckodrive.com/support.html
