This job file (and subsequent G-Code file) stops at line 30 in Mach with no explanation. I can single step thru it and it seems fine, but won't run.
Also-so far I've been running on a computer that isn't hooked up to the mill to check the code etc., but all through this process, the Mach DRO's don't show any changes as I mock run or single step thru the file. Is this normal for a setup that isn't actually connected to a mill?
Thanks.
