Hello Guest it is April 26, 2024, 04:52:58 AM
Author Topic: MR-J2S-A and Mach 3  (Read 21692 times)
Offline sdow
  •  67 67
MR-J2S-A and Mach 3
« on: October 28, 2013, 07:22:02 PM »
Hi
I have motors and drivers Mitsubishi  ... but i am need a help  ...how i can connect this drivers to mach3 ... can you propose me some controllers non very expensive to tray this ...
Thinks
Re: MR-J2S-A and Mach 3
« Reply #1 on: October 29, 2013, 03:14:42 PM »
If they accept step/dir (pulse/sign) then you have many options from the parallel port to smoothstepper to CSMIO, Galil, Kflop etc etc.
If they only accept Analogue input (+/- 10v) then there are a few controllers such as CSMIO/IP-A, DSPMC, Kflop/Kanalog
Offline sdow
  •  67 67
« Reply #2 on: October 29, 2013, 05:21:59 PM »
My drivers is MR-J2S-60A    .... i think hi can do step/dir
https://my.mitsubishi-automation.com/downloads/view/doc_loc/1375/138918.pdf?id=1375&saveAs=0&form_submit=View+now
if you can see page 24     hi can do with parameter 0011   ....   i never set this parameters  ... can you help me    ... or if you have a filet set it directly by PC   will be  good ..
Thinks
« Reply #3 on: October 30, 2013, 02:14:23 PM »
sorry I dont have the software :(
Offline sdow
  •  67 67
« Reply #4 on: October 30, 2013, 02:19:24 PM »
Hi
can you confirme me if J2S-60A   can do step/dir
thinks
« Reply #5 on: October 30, 2013, 02:23:56 PM »
Yes, as you pointed out page 3-24 shows the parameter to set for it.
Offline sdow
  •  67 67
« Reply #6 on: October 30, 2013, 02:33:51 PM »
and if i go with CSMIO   ... witch one i can choose ... he have many models    ... the CNC have 2 motors for axis X  (one each side of CNC)    1 motor for axiz X and 1 for axis Z   .
« Reply #7 on: October 30, 2013, 03:07:33 PM »
The IP-M or IP-S would work for you. The IP-M however is limited to 125KHz pulse so you may possibly have to use electronic gearing in the drive, that will depend on the steps per unit and velocity you had. The IP-S can pulse to 4MHz, so no electronic gearing would be required.
There are other controllers such as the Ethernet SmoothStepper (ESS) that can pulse to 4MHz as well but the ESS is only 5v I/O and also just single ended Step/Dir signals. You could possibly use single ended signals with your drives but they may be unreliable unless you are very particular about shielding. You ideally also want a breakout board if using the ESS, the CSMIO controllers dont require breakout boards.
Offline sdow
  •  67 67
« Reply #8 on: October 30, 2013, 10:09:11 PM »
Hi
If CSMIO can output 24V   on step/dir    i think that J2S-A is 24V .
Thinks
« Reply #9 on: October 31, 2013, 03:59:26 AM »
CSMIO/IP-M and IP-S  output 5v differential signals.
