I've just finished a pyrography stamp, I decided to do this one in stainless, possibly because I love a good steep learning curve
The text is 11mm high and 40mm wide -
In this instance for the cost of return P&P I'll mill off the date, giving the couple a pyrography stamp they can use to mark a wide range of things.
For hobby or low volume stuff an easier to machine material such as brass will be entirely suitable but I've had enquiries from furniture manufacturers and wanted to cover all the bases with the first job.
Things I've learned -
1. Use the option to rough out with a milling cutter, this will save huge amounts of time! It'll save engraving cutters too!
2. Make your stock big enough to allow the entire periphery of the job to be roughed with a milling cutter.
3. For fine detail work post the job twice, the second time with a smaller roughing milling cutter so that after roughing with a suitable milling cutter you can repeat the process with a smaller one and leave less work still for your engraving cutters.
4. Build or buy yourself a cutter grinder for sharpening your engraving cutters, you'll save yourself a mint in the long run
ATB,
Nick
