Hello to every one, my name is Mirko and i am a new user
I am running a 2"x 2" cnc from a german manufacturer with a controller and software called NC easy.
As a drawing program i am using Aspire 3.0
After my original cnc controller broke down i decided to get my machine up to date.
I changed all 3 stepper motors and set up an ethernet smooth stepper After a few small problems all went well with installation.
Yesterday i made a my first cut out with mach3 but i discovered a problem with partly missing tool path from my aspire drawing.
What i did:
1.) generating the tool path in aspire (different tools) and export them with the mach3 post processor (Mach2/3 ATC Arcs(mm) to a folder and saved it as a .TXT
2.) Load G code into mach3.
There are parts of the tool path and parts of some drawings missing. It does not happen if i separate the tool path in aspire (one tool only) and export them.
I hope someone can help me to solve this problem.
Many thanks
Mirko
