Hello Guest it is April 23, 2024, 11:00:48 AM
Author Topic: Need Help with Mach3 Post Processor(I think)  (Read 2829 times)
« on: September 30, 2013, 08:48:09 PM »
I have an operational machine, and have been cutting CUT3D demo files with it.
Mach 3 works fine.
I bought the license for Velectric VCarve Pro.... and created a part, the file looks good, but the MACH 3 is not working right, see attachment....
WHERE  DO i START TO FIX THIS?
I am using the same Mach 2/3-arcs(inch)- post processor.... need some advice
Re: Need Help with Mach3 Post Processor(I think)
« Reply #1 on: September 30, 2013, 09:12:57 PM »
Make sure in Mach3 that your IJ mode is set to Inc.
Although the V Carve Pro post processor should be automatically doing it for you with a G91.1.
« Reply #2 on: February 16, 2014, 12:11:55 PM »
Does quick reply mean Post??
I want to write G code long hand as I did with AH-HA but i'm stuck with radii
and circles. Is there any information around that would help?
I use Sheetcam but it has its(my) problems.
Brian Fairey.
« Reply #3 on: February 16, 2014, 12:32:41 PM »
The manual covers the different g-codes and how they're used. Asking specific questions is probably the best way to get help.
Use the "New Topic" button to start a new thread from any subforum.
