Hello Guest it is April 25, 2024, 06:05:18 AM
Author Topic: Wizard Safety Code BLOCK  (Read 6083 times)
« on: September 15, 2013, 10:52:51 AM »
HIYA RON, You may want to consider adding a FULL complement of Gcode to your safety code Blocks.
I see you may want to add  G50, G49, G40, G69
You would be amased when you start helping to sort out mach3 problems that the machine is LEFT in many ODD states from previous experimentation.
Re: Wizard Safety Code BLOCK
« Reply #1 on: September 15, 2013, 12:22:38 PM »
The new job dialog has a place where users can insert any startup code they want. I dont want to force to much on the users, but I agree we ought to include anything that matters to our wizard generated code.
« Reply #2 on: September 15, 2013, 08:22:32 PM »
The safety block is there to UNDO anything left wrong before running the Program. Best to reset everything than miss something important.
