Hello Guest it is April 25, 2024, 03:53:11 AM
Author Topic: Rectangle Pocket & Mill Rectangle  (Read 5316 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
« on: August 30, 2013, 11:07:19 AM »
Hello Ron,
 I tried doing a Rectangle Pocket .......
2.5" long by .5" wide using a .375" tool, but i got a pop up window while in the Pocket config window that states "Width must be larger than tool times 2."
So i tried a Mill Rectangle and the tool path shows lead in and out going beyond the width of rectangle.Look at screen shot.
Is this on the list or?
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Re: Rectangle Pocket & Mill Rectangle
« Reply #1 on: August 30, 2013, 11:16:04 AM »
Are you sure it will cut outside the box? remember what you see in the toolpath is the center line of the tool path
Put up a job file and I will make some tests.
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #2 on: August 30, 2013, 11:30:16 AM »
If i increase the width of pocket, then lead in and out appear inside of toolpath. Attached is job file. Ill give it a run on the mill and see what happens.
Troy
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #3 on: August 30, 2013, 11:50:30 AM »
Gave the Rectangle Gcode a try on the mill and the lead in & out starts outside of toolpath when trying to do an inside cut.
Troy
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #4 on: September 02, 2013, 07:48:10 AM »
So any reason why the cut starts outside of box?
Troy
« Reply #5 on: September 02, 2013, 10:13:49 AM »
It certainly was not planned to do that. I think I will just have to change the validate code to not allow rectangles that are to small for the code we use. Something will be done in the next release.
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #6 on: September 02, 2013, 10:28:35 AM »
Ok. Sounds good.
Just for thought.... do i understand correctly, the way NFS Mill and NFS addon generate Gcode is different? Asking because i can do a .500" wide pocket with a .375" dia endmill with no errors.
Troy
« Reply #7 on: September 02, 2013, 11:10:31 AM »
Yes, NFS Mill is a total new program. It is done in C++, the Addons were done in VB. We changed the whole process of generating code so nothing of the old VB code was included.
I will look at the old code to see if it helps improve the new.
