Hello Guest it is April 18, 2024, 05:30:49 PM
Author Topic: My newfangled Mw liscence file isnt loading  (Read 3872 times)
« on: August 11, 2013, 03:56:28 PM »
I just purchased and received the liscence file for the newfangled mill wizard. I try to load the license file as an administrator and  as a normal user and nothing happens. Any ideas on what i should do? Thank you for your responses.
Re: My newfangled Mw liscence file isnt loading
« Reply #1 on: August 11, 2013, 07:20:19 PM »
You should not need to be administrator. Are you using the latest versoin, 1.0.11? Are you using the license for the new mill wizard, not the old NFS addons for mill? After loading the file the about screen will not change, you must close the screen and re-open it to see the change.
« Reply #2 on: August 11, 2013, 07:44:25 PM »
I was logged on as my own user. I also tried it as an administrator. Neither worked Im using the current revision 1.0.11 on Windows 8. closing and reopening the screen showed no change in behavior; Nor, did rebooting et al.
« Reply #3 on: August 11, 2013, 09:42:22 PM »
Look inside the License file you received (open with text editor) look at the MAC address.
Now open NFW Mill Wizard and then HELP . Look at the PC  address that is shown there . ARE they the same Address ?
Just a thought, (;-) TP
