Hello Guest it is April 25, 2024, 07:29:53 AM
Author Topic: I have installed Mach3 Mill and the software stays in the emergency mode  (Read 8342 times)
Good morning, I have installed the software in order to control a Hummingbird M3V2 engraving machine. The instructions say that I should press the RESET button and that the exterior of the button will stay green. But in my case, this does not work. It stays in the "Emergency mode active". So what is the problem? Thanks
  •  9,199 9,199
Stefan,
Assuming your machine has an EStop button then check that you have the right configuration for it (active hi / low, correct port and pin etc.).
If you do not have an EStop button fitted - you should really fit one but in the short term...
Choose 'Emulated'  for your EStop configuration (Config / Ports & Pins / Input Signals). This should allow the on-screen RESET to be reset.
