Hello Guest it is April 24, 2024, 01:22:49 PM
Author Topic: Post processor G-code sherline 2010  (Read 10838 times)
« on: July 07, 2013, 10:57:27 AM »
Dear forum,
I have recently purchased a 4 axix Sherline 2010 CNC mill. I am currently using Camwotks and need to develop a post machine for camworks to generate G-code. I have been advised Fanuc OM should work ok however i just want to check on the forum as well as understand a little more myself (if only for self help)
I want to make a psot for sherline using the UPG (universal post generator) from camworks but as g code newbie its a bit of a sharp learning curve. See attached files for reference....
any help or guidance would be appreciated...
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
Re: Post processor G-code sherline 2010
« Reply #1 on: July 08, 2013, 03:28:21 AM »
Chances are that the Fanuc 0M will work unmodified.
« Reply #2 on: July 08, 2013, 06:30:11 AM »
thanks for the info, even with 4 axis mill
and the 4000 series lathe?
« Reply #3 on: July 08, 2013, 11:55:16 AM »
Idepends on what control system yo have on the sherline. Mach3 or LinuxCNC ?
IF the Fanuc OM does not do it try the Fanuc 6 post
Just a thought, (;-) TP
