Hello Guest it is April 25, 2024, 10:24:03 PM
Author Topic: Help Setting up Enroute for Mach3 Output  (Read 4207 times)
« on: July 05, 2013, 11:01:13 AM »
New to this forum. I bought a used home-built cnc XYZ router, computer, and Mach3 program and want to set up Enroute to output for Mach3. Does anyone know what machine driver to load to output to a .tap, a .nc or a .ncc code? Thanx for any assistance.
  •  9,199 9,199
Re: Help Setting up Enroute for Mach3 Output
« Reply #1 on: July 05, 2013, 11:41:19 AM »
« Reply #2 on: July 05, 2013, 12:40:00 PM »
Not much help. Thanx! The former owner would not transfer ownership of the Mach3 and Enroute software to me because I beat him up pretty good on the price. The only thing I need is what machine generates .tap, .nc or .ncc codes? My VCarve Pro will generate G codes (.tap), but I know Enroute much better, so it would be much easier to use it than to learn Vcarve.
« Reply #3 on: July 05, 2013, 01:01:06 PM »
My curves are not smooth in VCarve as seen in my photo. I was hoping that VCarve's G code was not generating a smooth code. Any suggestions?
« Reply #4 on: July 05, 2013, 02:33:53 PM »
The extension has nothing to do with IF Mach3 will run the code all it needs is a text version of the Gcode. The extension letters can be anything.
You just need the proper POST for the cam to output the proper Gcodes for mach3.
