Hi All.
Rather newbie to Mach3, and G-code.
Hand coded below:
Idea is to profile a 50x50 square, using climb mill, and G41 tool offset.
While doing so the toolpath is correct but rounds the corner with same Radius as the cutter.
Have tried:
Change settings to "Exact stop"
Add G61 to the init code
all gives rounded corners ?
If i change tool cutter radius to 0, I get sharp corners.
M06 T01 (Tool change #1)
G41 P5 (Left tool compensation, Radius = 5)
M03 s27000 M08 (SPINDLE AND FLOOD ON)
G00 x-5.0 y0.0 z0.0
G01 X0.0 F500.0
Z-1.0
Y50.0
x50.0
Y0.0
X0.0
G00 Z50.0
G40
M00
Where did I go wrong ?
Best Regards, Bo Andersen.
