Hello Guest it is April 25, 2024, 08:34:16 PM
Author Topic: Squares Are Not Square  (Read 3585 times)
« on: July 02, 2013, 04:15:39 AM »
I have an interesting problem with my CNC router.  I create drawings in AutoCAD, generate the CAM files with SheetCam, and drive the machine with a SmoothStepper.
I noticed that the inner corners of some square shapes I was contouring were more rounded than the radius of the cutting tool.  When I slowed the Y axis right down on Mach 3, the squares were no longer squares.
After slowing the Y axis down, the router cuts in the Y direction, and while the gantry decelerates before it gets to the corner the X axis starts moving.  So I get a parallelogram rather than a square.
I would expect that when cutting a square that the routing on one axis should complete before the other axis starts to move.  Very peculiar.
Help/advice appreciated.
David
  •  9,199 9,199
Re: Squares Are Not Square
« Reply #1 on: July 03, 2013, 01:27:39 AM »
Hi David,
Try increasing your Acceleration settings in motor tuning - this should do the trick.  ;)
As an alternative you could always select the 'Exact Stop' Motion Mode (Config/ General Config).
« Reply #2 on: July 03, 2013, 02:44:08 AM »
Exact Stop worked.  I hadn't taken note of this setting before.  The problem had never showed-up on any previous jobs.
thanks
David
« Reply #3 on: April 19, 2016, 02:36:21 PM »
Thanks Tweakie. Had exactly the same issue and your fix did it for me also :)
Bob
