Hello
Guest
it is
April 19, 2024, 11:57:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Support
Downloads
MACH TOOL BOX
G31 Probing Arrays
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: G31 Probing Arrays (Read 16144 times)
BR549
6,965
G31 Probing Arrays
on:
June 27, 2013, 04:33:42 PM »
Here are the G31 Probing arrays. It includes both the interior and exterior arrays along with the control Macro AND the USER'S Manual.
Logged
Bob La Londe
213
Re: G31 Probing Arrays
Reply #1 on:
June 28, 2013, 12:46:28 PM »
G31 Probing arrays? What is it exactly?
Logged
BR549
6,965
Reply #2 on:
June 30, 2013, 11:33:14 AM »
HIYA BOB it is a probing routine. You go to a start point of an object then run the array. It probes the int or ext profile of the part and stores the points in a points file for use to create a cutting solution for that object.
The array always has a focal point where the machine probes to. You can tune the array by where you place the focal point at.
If you read the manual it will give you a good idea as to what it is all about.
The array RUNS as a mach3 Gcode file so there is NO macro problems to deal with.
Logged
Bob La Londe
213
Reply #3 on:
July 01, 2013, 10:03:39 PM »
Cool. Thanks. I keep looking for solutions to make probing easier.
Logged
Jimster
176
Reply #4 on:
December 19, 2013, 09:17:10 AM »
Have you got any documentation to so explain how to use these arrays?
Logged
BR549
6,965
Reply #5 on:
December 19, 2013, 01:09:53 PM »
It is included in the Zip File as "G31 Probe Arrays .TXT"
Logged
Bob La Londe
213
Reply #6 on:
December 20, 2013, 06:06:23 PM »
I finally got around to trying this today. It probes one point (in the correct direction), goes back to the start point, and then retracts Z until it hits my limit switch.
What am I missing?
Logged
BR549
6,965
Reply #7 on:
January 10, 2014, 07:22:47 PM »
HI BOB which array were you running ??
Logged
birillo1959
165
Reply #8 on:
October 19, 2021, 02:03:10 AM »
GOOD MORNING
I downloaded the G31 Probing Arrays macro from the MACH TOOL BOX section
I installed "M1299.m1s" then I launched "G31ExtPolArrayV2.01.txt" and it gives me an error
I corrected the first line M1289 with M1299
Gcode starts but when the "G1Z3110" line is reached the Z axis goes to the end of its stroke.
(G31 External Polar Array V2.01)
M1289
M40
G90
G0 Z # 110
# 106 = [# 100 + # 102 * COS [# 103]]
# 107 = [# 101 + # 102 * SIN [# 103]]
G0 X # 106 Y # 107
G1 Z # 123
122 = Fix [# 122] <-------------- maybe it should be # 122 = Fix [# 122]
M98 P1 L # 122
G1Z3110 <-------- --------------------------------
M41
M30
o1 (sub1)
# 123 = [# 123 + # 121]
G1 Z # 123
M98 P2 L # 108
M99
o2 (sub)
# 105 = [# 103 + # 104]
# 106 = [# 100 + # 102 * COS [# 105]]
# 107 = [# 101 + # 102 * SIN [# 105]]
G90
G0 X # 106 Y # 107
G31 X # 100 Y # 101
# 103 = # 105
m99
given its usefulness it would be possible to correct it
I use version 3.043.062
I thank those who can help me
Logged
Graham Waterworth
2,672
Yorkshire Dales, England
Reply #9 on:
October 19, 2021, 08:01:08 PM »
Try it like this :-
M1289
M40
G90
G0 Z#110
#106 = [#100 + #102 * COS [#103]]
#107 = [#101 + #102 * SIN [#103]]
G0 X#106 Y#107
G1 Z#123
#122 = Fix [#122]
M98 P1 L#122
G1 Z#110
M41
M30
o1 (sub1)
#123 = [#123 + #121]
G1 Z#123
M98 P2 L#108
M99
o2 (sub)
#105 = [#103 + #104]
#106 = [#100 + #102 * COS [#105]]
#107 = [#101 + #102 * SIN [#105]]
G90
G0 X#106 Y#107
G31 X#100 Y#101
#103 = #105
m99
Logged
Print
Pages:
1
2
Go Up
« previous
next »
