Hello Guest it is April 26, 2024, 03:55:03 AM
Author Topic: re crop circles in wizard radius turn  (Read 2598 times)
« on: June 14, 2013, 08:09:12 PM »
Hi everyone i am having the crop circle problem in turn with the latest version of Mach turn R3. 043,66, i read all i could on the subject and i am in ABS ,IJ Incremental mode and i have the reverse tool post box unchecked but it keeps coming out with a inverted circle on the end of the shaft.
I am currently getting a post modified for turn and i got the threading fixed but now i have this problem and am a little lost as as what to try ,the inverted circles are coming from the wizard and the preview looks weird.
I have attached a g code sample file with the offending code .
Thank's to all who reply or take a look ???
Re: re crop circles in wizard radius turn
« Reply #1 on: June 14, 2013, 10:16:04 PM »
Try checking reversed arc's ,use diameter mode. Then also ABS for distance and IJ Mode. Works fine in 3.042.33 here.
Can't speak for the latest greatest version of Mach.
« Reply #2 on: June 14, 2013, 10:54:36 PM »
Thanks Rich ,must be my version because i have all those settings already, i will try and download a different version and see what i get after i back everything up.
