Hello Guest it is April 25, 2024, 06:55:25 PM
Author Topic: Charge Pump problems  (Read 5822 times)
« on: May 29, 2013, 09:47:01 PM »
I am trying to set up a  Syil M4 machine. Its BOB requires a charge pump, but its on pin 9. If I run with the parallel port it works fine, but if I insert the USB SS it will not run.
Is there a problem with using pin 9?
Anyone have a Syil M4 working?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Charge Pump problems
« Reply #1 on: May 30, 2013, 08:17:41 AM »
You are using the same profile and just switching the motion control device? Have you checked to see if a signal is coming out of pin 9 on the SmoothStepper? If you don't have an oscilloscope you can use a voltmeter. When the charge pump signal is off you should read zero or five volts and when it is running you will read about 2.5 volts.
I've seen a few strange problems in the past where a corrupt profile caused external motion devices to work one way and the parallel port a different way. One test is to start a profile from scratch and see if that changes things.
Happy machining , Jeff Birt
« Reply #2 on: October 16, 2013, 03:28:59 AM »
why is this function called "Charge Pump?"
« Reply #3 on: October 16, 2013, 08:45:23 AM »
The circuit uses a pulse stream to charge a capacitor. If the pulse stream stops the circuit switches the drivers off. Its kind of like the pulse keeps 'pumping' a charge into the capacitor.
Its done this way as a safety- there is no way Mach could keep doing the regular pulse if it has crashed or 'gone nuts' in some way. If the enable was simply a signal, either on or off, it could fail with the signal in the safe state, but mach could be totally dead.
« Reply #4 on: October 16, 2013, 09:21:30 AM »
Ah Huh... Roger that. Makes sense. RC discharge circuit. Thank you.
