Hello Guest it is April 16, 2024, 02:58:38 PM
Author Topic: no power to z  (Read 9313 times)
no power to z
« on: May 19, 2013, 05:05:55 PM »
xy works, put other motor on z, nutin.   Mach3 shows z moving.   Had tried a program called calypso and removed it.  reloaded mach3 ????
Re: no power to z
« Reply #1 on: May 20, 2013, 05:06:02 AM »
try swapping drives from x or y to z
Re: no power to z
« Reply #2 on: May 20, 2013, 05:31:37 AM »
Do you have the correct pins and port number set for your Z?
Re: no power to z
« Reply #3 on: May 20, 2013, 02:19:41 PM »
I keep a written record of all pin setups, I believe they work before.  I changed z to x and x did not work.  I believe my problem is in the controller or the smoothstepper board???????
Re: no power to z
« Reply #4 on: May 20, 2013, 02:21:52 PM »
I did inhibit z once, maybe I did something to that
Re: no power to z
« Reply #5 on: May 20, 2013, 02:23:02 PM »
maybe that calypso program did somthing
Re: no power to z
« Reply #6 on: May 20, 2013, 02:52:47 PM »
Re: no power to z
« Reply #7 on: May 20, 2013, 03:08:17 PM »
Post your xml and I'll have a look.
Re: no power to z
« Reply #8 on: May 20, 2013, 03:42:57 PM »
ok Thanks
Re: no power to z
« Reply #9 on: May 20, 2013, 04:06:39 PM »
Are you jogging from the keyboard ?
If so, you have some weird extended ASCII codes for Z.
Set Z Jog for Page UP and Down and it works fine in sim here.
Does it work from your Pendant fly-out ?
....till Brett gets back to ya .....
Russ
