Hello
Guest
it is
April 19, 2024, 02:04:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
BobCad/Cam setting incorrect measurement units in Gcode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: BobCad/Cam setting incorrect measurement units in Gcode (Read 3990 times)
magicniner
265
on:
May 05, 2013, 07:30:58 PM »
I've been having grief all evening with scaling and Mach3 reporting moves exceeding soft limits.
After pulling my hair out for a while I found that Mach3 mysteriously changed to inches every time I loaded the G-code.
Using an online G-Code reference to find the "Units" codes and then checking the output from BobCad/Cam revealed the G20 inch command.
With G20 edited to G21 the code runs great.
Units are set to mm in both
Settings - Part
and
Settings - Default
in BobCad/Cam V25, it's using the Mach3 no ATC post and units are set to mm in Mach3
Have I missed something?
Logged
budman68
2,352
Re: BobCad/Cam setting incorrect measurement units in Gcode
Reply #1 on:
May 06, 2013, 05:08:23 AM »
I have no experience with this software, but this fella seems to:
http://www.machsupport.com/forum/index.php/topic,21342.0.html
Logged
Dave->
magicniner
265
Reply #2 on:
May 08, 2013, 04:25:36 AM »
It seems it's hard coded in the Post rather than passed across from CAM to Code, I can live with editing one character until I find which bit of the post to edit to make a permanent change,
I'll get there,
Nick
Logged
Print
Pages:
1
Go Up
« previous
next »
