Hello Guest it is September 18, 2026, 03:01:44 AM
Author Topic: Simple M6 Manual Tool Change  (Read 146212 times)
Re: Simple M6 Manual Tool Change
« Reply #10 on: April 30, 2013, 05:49:08 PM »
I just took a look, and the stock macro's don't move to the tool change position. They do move back to the previous position after the tool change, though. The 2010 screenset that I sell  will move the tool to the toolchange position, and zero the tool for you automatically, in case you're interested. :)
« Reply #11 on: April 30, 2013, 09:17:11 PM »
Hi Gerry ,
Your Screen looks great , and has the manual tool change function that I was asking about , for the price you are asking I will be purchasing a copy and you seem to support your software with good tutorials for novices like me .. will be in contact soon .
« Reply #13 on: March 26, 2014, 04:41:23 AM »
No, all of the old links are broke now. I just updated the links in my earlier post.
« Reply #14 on: September 30, 2014, 04:28:16 PM »
I am using Mach3 Turn to run an Emco Turn 50 Lathe. I would like to use CNCBase software to write code. The problem I am having is that Mach 3 wants a different format for tool changes than I am used to. If I enter M3 T3, it gives me an invalid tool selection (Tool 0). If I enter M6 T0303 or M6 T300, it works. Can anything be changed to make it use a standard tool number?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #15 on: October 01, 2014, 04:19:08 PM »
T0606 and the like is standard for turning T6 M6 is standard for mills and routers.
« Reply #16 on: April 23, 2019, 04:53:10 AM »
is there a macro available to get the "tool change location" option in mach3 to function,,,and goto x,y,z bed loaction when a tool change is requested .
Offline ZASto
  •  434 434
« Reply #17 on: April 23, 2019, 06:59:10 PM »
On settings page there are three DROs for tool change location. They are in Machine Coordinates!!!
Machine should go to that location when Mach encounters M6 Tx.
My personality is who I am.
Offline reuelt
  •  520 520
« Reply #18 on: April 26, 2019, 01:45:11 PM »
is there a macro available to get the "tool change location" option in mach3 to function,,,and goto x,y,z bed location when a tool change is requested .
'You will need to edit m6Start.m1s macro (add the following lines there) to do that.
ToolChangeX = GetUserDRO(1200)            'Get user defined tool change location
ToolChangeY = GetUserDRO(1201)
ToolChangeZ = GetUserDRO(1202)
If IsSafeZ() Then               'If SafeZ is defined,
   safeZ = GetSafeZ()            'use it for positioning commands
Else
   safeZ = 0               'Otherwise, moves are made at MC Z0
End If
Code" G53 G0 Z" & safeZ               'Position spindle for tool change
While IsMoving()
Wend
Code"G53 G0 X" & ToolChangeX & "Y" & ToolChangeY
While IsMoving()
Wend
Code"G53 G0 Z" & ToolChangeZ
While IsMoving()
Wend
« Last Edit: April 26, 2019, 01:47:53 PM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
Offline reuelt
  •  520 520
« Reply #19 on: April 26, 2019, 02:24:53 PM »
'please add safez=0 to get it defined
safeZ=0
Else
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
