Hello Guest it is April 25, 2024, 12:42:37 PM
Author Topic: TS3040C-H80 Mach3Mill.xml file setup correctly with swapped X and Y axis  (Read 10238 times)
Offline m9g
  •  26 26
Hi
I have finally sorted this machine and have it setup correctly after a lot of available manuals for the same machine with different settings.
I have swapped the default X and Y axis around for what I consider to be a better working area and better suited to most cad/cam software.
After downloading file, if you want to then rename it or leave as it is and put it into C:\Mach3 folder. REMEMBER to open mach3 then choose this file rather than the standard mach3mill.xml file
Here is the XandYswappedMach3Mil.xml file......
