Hello Guest it is April 24, 2024, 09:03:09 AM
Author Topic: MachIII GCode Leadin questions  (Read 6199 times)
Re: MachIII GCode Leadin questions
« Reply #10 on: April 23, 2013, 10:25:19 AM »
I guess it is best to ask are you running the pro version of Lcam that actually does tool radius comp?
« Reply #11 on: April 24, 2013, 07:24:42 AM »
I still do not see where or how MachIII gets told what type of leadin is being used.
As Terry replied, you need the pro version of LC for advanced features of LC.
You are reponsible for defining where and the type of lead you want to use. LC will do it automaticaly, or try to , and that info
is in Tutorial #7. There are a number of options to select the type. LC will show the leadin / out in the graphics area and post code. The posted code contains the gcode which will be used by Mach.
« Reply #12 on: April 24, 2013, 08:09:09 AM »
Simple example of lead in  / out with code from LC.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #13 on: April 24, 2013, 08:33:02 AM »
but... whatever means are used to get leadins/outs into your code, they are just G1, G2, G3 moves or combinations thereof (as has been said).
That's why I had a little poke to post your code and then we could point them out to you.
Ian
