Hello Guest it is April 25, 2024, 10:26:49 AM
Author Topic: G02 G03 Mach3 bug  (Read 6528 times)
G02 G03 Mach3 bug
« on: April 15, 2013, 02:37:33 PM »
Hi Guys, I figured out what is causing the recurring G02 G03 problems, it's a Mach3 bug.  When the arc starts in the positive X,Y quadrant and ends in a negative one where either X or Y are negative, Mach3 calculates the radius of the curve wrong and gives you an error even though the cnc code is technically correct.
Example:  The gcode below works because the arc begins and ends in the (+) X,Y quadrant.
G94 F1.5
G00 Z0.50
G00 X7.5000 Y1.6000
G01 Z-0.15
G17
G01 X1.6000 Y1.6000
G03 X0.0000 Y0.0000 I0.0000 J-1.6000
G01 X0.0000 Y-6.0000
G00 Z0.50
M02
The gcode below DOESN'T work because the Y-value ends up negative at the end of the arc.
The only difference is all the Y values have been lowered by 1.6.
G94 F1.5
G00 Z0.50
G00 X7.5000 Y0.0000
G01 Z-0.15
G17
G01 X1.6000 Y0.0000
G03 X0.0000 Y-1.6000 I0.0000 J-1.6000
G01 X0.0000 Y-7.6000
G00 Z0.50
M02
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
Re: G02 G03 Mach3 bug
« Reply #1 on: April 15, 2013, 08:50:16 PM »
Do you have I&J set to Inc or Abs in config window?
Graham
« Reply #2 on: April 15, 2013, 09:21:23 PM »
The second code works fine here. How did it fail for you?
