Hello
Guest
it is
April 24, 2024, 08:20:42 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
clientwakeup board!?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: clientwakeup board!? (Read 3650 times)
cam4ge
20
on:
April 11, 2013, 04:26:48 PM »
i keep getting the error clientwakeup board not responding. how do i fix this problem?
Logged
Jeff_Birt
1,107
Re: clientwakeup board!?
Reply #1 on:
April 12, 2013, 02:06:38 PM »
That message is telling you the plug-in can't talk to the ESS. Most likely causes are that you don't have your PCs network adapter configured properly or your firewall is blocking the communication.
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
Jeff_Birt
1,107
Reply #2 on:
April 12, 2013, 04:41:16 PM »
I just got your voicemail from yesterday. Does your PC have an internet connection as well? If so I can remote in so we can both see the screen. It is typically much easier to find the issue if we can talk and both see the screen at the same time.
Logged
Check out
www.soigeneris.com
cam4ge
20
Reply #3 on:
April 14, 2013, 01:41:55 AM »
thank you Jeff .i do have internet at my shop. i have now gotten past that one. the only thing i need now is to configure a pmdx126 board for an ethernet smooth stepper. i am having trouble configuring using my methods.aka trial and error.
Logged
Print
Pages:
1
Go Up
« previous
next »
