Hello Guest it is April 19, 2024, 06:22:38 PM
Author Topic: mach3 different from machscreen  (Read 14074 times)
« on: March 26, 2013, 02:06:43 PM »
is there a setting where i can see in machscreen what i see in mach3 ?
attached explains better.
Kenneth
Re: mach3 different from machscreen
« Reply #1 on: March 27, 2013, 07:29:19 AM »
Hi Kenneth,
in the picture mach3.png the red led's are using Bitmaps, while in the picture screen.png there are no Bitmaps used. Could it be the referenced bitmap files lie in different directories?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: March 27, 2013, 08:33:50 AM »
i made the set file with machscreen. picture files are in the same place.
don't know where mach3 gets it pic files. first location is mostly my
pic. other location is where default pic are
C:\Mach3\Bitmaps
C:\Mach3\Bitmaps\MillBitmaps
Kenneth
« Reply #3 on: March 27, 2013, 09:12:33 AM »
Hi Kenneth,
please check following Settings in       Options -> Settings -> Generic prog Settings :
is the button "Report missing files" checked? If so, does a Message box pop up, when you load the screenset in MachScreen?
Is the "User defined image path" field empty?
Klaus
« Reply #4 on: March 27, 2013, 09:19:53 AM »
"report missing image files" is checked. and no warning about missing file
pops up when loading file. had that before.
Kenneth
« Reply #5 on: March 27, 2013, 09:24:43 AM »
Hi Kenneth,
How about:
Klaus
« Reply #6 on: March 27, 2013, 09:27:41 AM »
no sir,
C:\Mach3\Bitmaps\
Kenneth
« Reply #7 on: March 27, 2013, 09:33:36 AM »
Hi Kenneth,
please clear that field. If this field is empty, you will have the same look in Mach3 and MachScreen
Klaus
« Reply #8 on: March 27, 2013, 09:47:18 AM »
cleared the field and same results.
closed mach3 and machscreen. same.
made change in machscreen and saw results in mach3.
but get same placement as pictured here
Kenneth
« Reply #9 on: March 27, 2013, 10:54:11 AM »
Hi Kenneth,
could you please:
start MachScreen
load screenset
use menu File -> Project Export
in the pop up dialog "Export path" select drive c:   Create new Folder c:\ScreenTest click OK
zip directory including subdirectories to C:\ScreenTest
send me the zipped file
klaus.dietz@kd-dietz.de
Klaus
