Hello Guest it is April 25, 2024, 03:37:39 PM
Author Topic: Conversational Gcode Wizard  (Read 8282 times)
« on: March 25, 2013, 04:35:40 PM »
Guys Here is a wizard that allows you to create a Gcode program Directly in MACH3 using Gcode Commands. As you add line by line the tool path updates and shows you your move. You can add or delete line by line as you go.
It can create your header/safety block for you and will CLOSE OUT the program and allow you to NAME your program and save.
It also allows YOU to go OFFLINE with MACH3 so there is NO machine movement by accident. When you return to mach3 it put MACh3 back online in case you forget.
You can also dry run you program onscreen (Mach3 OFFLINE) so you can test the program for errors or OOPS.
Let me know if there is trouble or things you may need to add. I will give it a shot.
Just UNZIP the file into your ADDONS directory.
« Last Edit: March 25, 2013, 04:42:35 PM by BR549 »
