Example of a first couple of lines look like when i make it from inkscape
(Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
M3
(Header end.)
G21 (All units in mm)
(Tool diameter should be at least 10.0 mm)
(Depth, as a function of radius w, must be 10)
(Rapid feeds use safe Z=5.0 mm)
(Material surface at Z=0.0 mm)
(Change tool to Default tool)
G00 Z5.000000
G00 X117.431962 Y93.294371
G01 Z-0.203285 F100.0(Penetrate)
G01 X117.388358 Y93.020983 Z0.000000 F400.000000
G01 X117.431962 Y93.294371 Z-0.203285
G01 X117.045628 Y93.881139 Z-0.262438
G01 X116.831478 Y94.819726 Z-0.239296
G01 X116.854930 Y95.344857 Z-0.198572
G01 X117.135262 Y97.272801 Z-0.241864
G01 X117.147990 Y97.321993 Z-0.237490
G01 X117.598445 Y98.724524 Z-0.195552
G01 X117.654042 Y98.918919 Z-0.151553
G01 X118.445224 Y100.337283 Z-0.169192
G01 X118.471076 Y100.383596 Z-0.169785
G01 X119.185183 Y101.601554 Z-0.215420
G01 X119.893532 Y102.822617 Z-0.254536
G01 X120.576397 Y104.126455 Z-0.231733
G01 X120.614497 Y104.205562 Z-0.233116
G01 X121.225226 Y105.613315 Z-0.196342
G01 X121.273740 Y106.331458 Z-0.241018
G01 X121.296910 Y106.908066 Z-0.261168
G01 X121.007012 Y107.280119 Z-0.168995
G01 X120.314946 Y107.060296 Z-0.306888
G01 X119.969619 Y106.553397 Z-0.286540
G01 X119.537255 Y105.802375 Z-0.293963
G01 X118.939819 Y104.771023 Z-0.307340
G01 X118.456570 Y104.206550 Z-0.309880
G01 X117.561982 Y103.813019 Z-0.316710
G01 X117.226476 Y103.910499 Z-0.308638
