Hello Guest it is April 26, 2024, 05:16:21 AM
Author Topic: N code?  (Read 2678 times)
N code?
« on: March 18, 2013, 11:18:29 PM »
Has anyone seen their g codes with N at the beginning of each line?  Running deskproto and the codes are a little weird when loading to Mach..the display doesn't even show the item being cut
Helpless jeweler ???
Re: N code?
« Reply #1 on: March 19, 2013, 12:58:50 AM »
N is used to tell you it is a line number.  You can load code into Mach and double left click the g code display to add line numbers.  Double click again to remove them.  Most post processors can also be set to add line numbers to your code.  Helps to trouble shoot when you can say at line number **** it mess's up.
« Last Edit: March 19, 2013, 08:19:56 PM by Chaoticone »
Re: N code?
« Reply #2 on: March 19, 2013, 06:50:45 PM »
« Last Edit: March 19, 2013, 06:57:14 PM by BR549 »
Re: N code?
« Reply #3 on: March 19, 2013, 08:19:06 PM »
TP told me he believes that the " : " charactor is invalid in MAch3 G code as in
N1200:   G0 X0 Y0 Z0 so disregard my comment earlier in this topic.  I will edit it so hopefully it wont mess anyone else up.
Thanks TP!
