Hello Guest it is April 19, 2024, 04:05:49 PM
Author Topic: Gcode on Circle, Arc and feed rate errors  (Read 10071 times)
« on: March 17, 2013, 06:14:18 PM »
I recently purchase licensed versions of Mach3 Version R3.043.066, and Newfangled Mill Wizard Version 1.03 and install them on my PC running Windows XP professional, and everything seem to be working fine with the exception of making up the Gcode in Newfangled Mill Wizard for Circles Arcs or Arc plunge and try to run it in Mach3.  I get an error code.
Zero radius arc, Block= G02 X-22.2250 I-22.2250 F100.0
See Code below:
(***New File Started***)
(created by NFS Mill, V4)
(New File Started 03/16/13 14:31:48)
(posted for Aluminum )
(Strategy: Equal )
(Rapid height: 10.0000  Clearance height: 2.0000 )
G98 G80 G17 G90 G54 G64
G21 G90
(***New Tool Selected***)
(ToolNum: 05  Diameter: 6.3500  )
(Feed: 100.0000  SFM: 259.0000  Plunge: 20.0000  ChipLoad: 0.0635  )
M9
M5
M06 T5 ()
G43 H5
M03 S4500
(***Cut Circle***)
(Xorign: 0.0000  Yorign: 0.0000  Dia: 50.8000  InOut: 00 Dir: 00  )
(Ztop: 0.0000  Zdepth: -6.3500  Zstep: 1.2700 )
(will make  5.0000  cuts of:  1.2700 )
G00 Z10.0000
X22.2250 Y0.0000
Z2.0000
G01 Z0.0000 F20.0
G02 X16.7924 Y-14.5591 Z-1.2700 I-22.2250
G03 X22.2250 Y0.0000 I-16.7924 J14.5591
G02 X-22.2250 I-22.2250 F100.0        : THIS LINE:
X22.2250 I22.2250
G01 F20.0
G02 X16.7924 Y-14.5591 Z-2.5400 I-22.2250
X22.2250 I22.2250
G01 F20.0
G02 X16.7924 Y-14.5591 Z-3.8100 I-22.2250
X22.2250 I22.2250
G01 F20.0
G02 X16.7924 Y-14.5591 Z-5.0800 I-22.2250
X22.2250 I22.2250
G01 F20.0
G02 X16.7924 Y-14.5591 Z-6.3500 I-22.2250
X22.2250 I22.2250
G00 Z10.0000
M09
M05
M30 (end of file)
The other problem I am having is the Feed Rate on some of the Programs cutting options for example the Rectangle function the plunge feed rate is the only one carried through the entire Gcode See code below
(New File Started 03/17/13 13:56:52)
(Strategy: Equal )
(Rapid height: 5.0000  Clearance height: 1.0000 )
G21 G90
(Feed: 100.0000  SFM: 259.0000  Plunge: 10.0000  ChipLoad: 0.0635  )
M9
M5
M06 T5 ()
G43 H5
M03 S4500
(***Cut Rectangle***)
(Xorign: 0.0000  Yorign: 0.0000  Length 50.0000  Width: 50.0000  CorR: 0.0000  InOut: 00  )
(Ztop: 0.0000  Zdepth: -6.3500  Zstep: 3.1750 )
(will make  2.0000  cuts of:  3.1750 )
G00 Z5.0000
X-21.8250 Y21.8250
Z1.0000
G01 Z0.0000 F100.0
F10.0                          :THIS FEED RATE IS THE LAST CHANGE:
X-12.5419 Z-3.1750
X-21.8250
X21.8250
Y-21.8250
X-21.8250
Y21.8250
X-12.5419 Z-6.3500
X-21.8250
X21.8250
Y-21.8250
X-21.8250
Y21.8250
G00 Z5.0000
M09
M05
M30 (end of file)
 Thank you
Michael
Re: Gcode on Circle, Arc and feed rate errors
« Reply #1 on: March 17, 2013, 07:35:41 PM »
Ok, I found the problem- we set the feed to plunge rate before doing the ramp, then forgot to reset it to feed rate after ramp. This was both linear and helical ramps.
We will post an update soon.
« Last Edit: March 17, 2013, 07:40:09 PM by Ron Ginger »
« Reply #2 on: March 26, 2013, 06:42:57 PM »
Hi Ron
Any word on when a fix (update version) to the Arch, circle, feed rate, Gcode problem for the Newfangled Mill Wizard??
Michael
« Reply #3 on: March 26, 2013, 06:54:38 PM »
I am going to Brians shop tomorrow, we will talk about a better way for me to update the installer. Right now I have to depend on Scott to do it.
« Reply #4 on: April 10, 2013, 12:10:59 AM »
Hi Ron
Checking on the fix to the Arch, circle, feed rate, Gcode problem, any idea when an (update version) to the Newfangled Mill Wizard is to be release??
Michael
« Reply #5 on: April 10, 2013, 07:25:01 AM »
Brian is having the web site re-worked, and he is  trying to find a way I can update just the wizard installer.
I have attached an exe file to this message. If you download it, unzip it and put the NFS-mill.exe file into the program files folder to replace the current one it ought to work.
If for some reason this fails, just re-run the release installer, it will put everything back.
Sorry I dont have a better way to do this yet. We will, but its going to be a couple weeks. I am leaving today for Cabin Fever and NAMES shows, not back until April 23. I will be following mail and this forum, but will not have access to the dev machine. Brian and the rest of the Mach crew will be leaving tomorrow for Cabin Fever.
« Reply #6 on: January 04, 2015, 05:38:06 PM »
Hi Ron,
I am using Mill Wizard and always have low feed rate in circles;   this is the problem discussed here ?  and above file fixes it ?  if
« Reply #7 on: January 04, 2015, 05:40:40 PM »
Hi Ron,
Above not completed;  creating a code with the wizards (the old version) the feed rate is OK.; I am using version Mill Wizard ver 1.00;  what is the latest one ?
Thank you
« Reply #8 on: January 04, 2015, 05:47:30 PM »
The latest version on the web is 1.0.17 I think it has most of the feed rate fixes except for keyslot. That has been fixed in the code but that version is not on the net yet.
« Reply #9 on: January 04, 2015, 07:04:09 PM »
Hi Ron,
Tks for the feedback;  tried again and worked but need to uncheck the "Spiral Z step"  if checked feed-rate keeps low;  understood very soon will have a new release and hope all this is fixed.; correct ?
Thank you
