Hello Guest it is April 24, 2024, 12:41:53 AM
Author Topic: control emergency LED (LED19) with mach3  (Read 3760 times)
« on: March 13, 2013, 03:41:43 AM »
hi,
i'm newbie in mach3 and pokeys. i have had no issues with general setup of pokeys56E in mach3.
first little problem i have is with controlling leds.
I would like to have a LED which is ON when mach3 is in emergency mode.
so I connected LED to pin1 of pokeys56e (anode to +3v3 via 690R resistor, cathode to pin1).
configured pokeys56e for LED19 as in enclosed picture (LED19.jpg) and it doesn't work. LED is always OFF.
I tried with LED67 (offline indicator) and it is working fine. LED is changing status (ON/OFF)
when clicking offline button.
any advice ?
PS: i'm using mach3 v3.043.066 (currently only demo) and latest pokeys56e software.
Offline NeoTO
  •  504 504
    • PoLabs
Re: control emergency LED (LED19) with mach3
« Reply #1 on: March 13, 2013, 04:46:57 AM »
Try using the OEM LED 800, "Reset LED"
« Reply #2 on: March 13, 2013, 05:01:13 AM »
hi,
OEM LED800 works :-) When in reset state (Emergency switch activated) LED is blinking.
Thanks !
Any idea when the OEM LED 19 can/should be used ?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: March 13, 2013, 05:06:05 AM »
LED800 reflects the Mach3's internal emergency state. I am not sure how the LED 19 is handled.
